Connection-based proof construction in Non-Commutative Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We propose a connection-based characterization of the multiplicative fragment of non-commutative logic (MNL), that is a conservative extension of both commutative (MLL) and non-commutative or cyclic (MCyLL) linear logic. It is based on a characterization for MLL together with the introduction of labels and constraints from a formula polarization process. We also study a similar characterization for the intuitionistic fragment of MNL. Finally, we consider the relationships between these results and proof nets construction in MNL based on labels and constraints.
inria-00099554 , version 1 (26-09-2006)
Didier Galmiche, Jean-Marc Notin. Connection-based proof construction in Non-Commutative Logic. 10th International Conference on Logic for Programming Artificial Intelligence and Reasoning 2003 - LPAR'03, 2003, Almaty/Kazakhstan, pp.422 - 436, ⟨10.1007/b13986⟩. ⟨inria-00099554⟩
84 Consultations
0 Téléchargements
