A Rule-Based Approach for Automated Generation of Kinetic Chemical Mechanisms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Several software systems have been developed recently for the automated generation of combustion reactions kinetic mechanisms using different representations of species and reactions and different generation algorithms. In parallel, several software systems based on rewriting have been developed for the easy modeling and prototyping of systems using rules controlled by strategies. This paper presents our current experience in using the rewrite system \ELAN\ for the automated generation of the combustion reactions mechanisms previously implemented in the \EXGAS\ kinetic mechanism generator system. We emphasize the benefits of using rewriting and rule-based programming controlled by strategies for the generation of kinetic mechanisms.
Autre [cs.OH]
Fichier non déposé
inria-00099621 , version 1 (26-09-2006)
  • HAL Id : inria-00099621 , version 1
Olivier Bournez, Guy-Marie Côme, Valérie Conraud, Hélène Kirchner, Liliana Ibanescu. A Rule-Based Approach for Automated Generation of Kinetic Chemical Mechanisms. 14th International Conference on Rewriting Techniques and Applications - RTA'2003, Jun 2003, Valencia, Spain, pp.30-45. ⟨inria-00099621⟩
100 Consultations
0 Téléchargements
