Design of live and maximally permissive Petri net controller using theory of regions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Robotics and Automation Année : 2003
This paper addresses the forbidden state problem of Petri nets (PN) with liveness requirement and uncontrollable transitions. The proposed approach computes a maximally permissive PN controller, whenever such a controller exists. The first step, based on a Ramadge-Wonham like reasoning, determines the legal and live maximal behavior the controlled PN should have. In the second step, the theory of regions is used to design control places to add to the original model to realize the desired behavior. Furthermore, necessary and sufficient conditions for the existence of control places realizing the maximum permissive control are given. A parameterized manufacturing application of significant state space is used to show the efficiency of the proposed approach.
Fichier non déposé
inria-00099640 , version 1 (26-09-2006)
  • HAL Id : inria-00099640 , version 1
Asma Ghaffari, Nidhal Rezg, Xiaolan Xie. Design of live and maximally permissive Petri net controller using theory of regions. IEEE Transactions on Robotics and Automation, 2003, 19 (1), pp.137-141. ⟨inria-00099640⟩
116 Consultations
0 Téléchargements
