A Fast Algorithm for Testing Reducibility of Trinomials mod 2 and Some New Primitive Trinomials of Degree 3021377
The standard algorithm for testing reducibility of a trinomial of prime degree $r$ over $\GF(2)$ requires $2r + O(1)$ bits of memory. We describe a new algorithm which requires only $3r/2 + O(1)$ bits of memory and significantly fewer memory references and bit-operations than the standard algorithm. If $2^r-1$ is a Mersenne prime, then an irreducible trinomial of degree $r$ is necessarily primitive. We give primitive trinomials for the Mersenne exponents $r = 756839$, $859433$, and $3021377$. % The results for $r = 859433$ extend and correct some computations of Kumada {\etal}. The two results for $r = 3021377$ are primitive trinomials of the highest known degree.
