Near-Optimal Parameterization of the Intersection of Quadrics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
In this paper, we present the first exact, robust and practical method for computing an explicit representation of the intersection of two arbitrary quadrics with rational coefficients. Combining results from the theory of quadratic forms, linear algebra and number theory, we show how to obtain parametric intersection curves that are near-optimal in the number and depth of radicals involved.
Autre [cs.OH]
SoCG03.pdf (292.22 Ko) Télécharger le fichier
inria-00099789 , version 1 (16-12-2009)
Laurent Dupont, Daniel Lazard, Sylvain Lazard, Sylvain Petitjean. Near-Optimal Parameterization of the Intersection of Quadrics. 19th Symposium on Computational Geometry - SoCG 2003, Jun 2003, San Diego, United States. pp.246-255, ⟨10.1145/777792.777830⟩. ⟨inria-00099789⟩
172 Consultations
233 Téléchargements
