Higher-order Matching in the Linear lambda-calculus with Pairing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We prove that higher-order matching in the linear $\lambda$-calculus with pairing is decidable. We also establish its NP-completeness under the assumption that the right-hand side of the equation to be solved is given in normal form.
Fichier non déposé
inria-00100082 , version 1 (26-09-2006)
  • HAL Id : inria-00100082 , version 1
Philippe de Groote, Sylvain Salvati. Higher-order Matching in the Linear lambda-calculus with Pairing. 18th International Workshop on Computer Science Logic - CSL'2004, Sep 2004, Karpacz, Poland, pp.220-234. ⟨inria-00100082⟩
223 Consultations
0 Téléchargements
