Role-Based Access Control for XML Enabled Management Gateways
While security is often supported in standard management frameworks, it has been insufficiently approached in most deployment and research initiatives. In this paper we address the provisioning of a security ``continuum'' for management frameworks based on XML/SNMP gateways. We provide an in depth security extension of such a gateway using the Role Based Access Control paradigm and show how to integrate our approach within a broader XML-based management framework.
