Improving Business Process Quality through Exception Understanding, Prediction, and Preventing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Daniela Grigori
  • Fonction : Auteur
  • PersonId : 835377
Fabio Casati
  • Fonction : Auteur
Umesh Dayal
  • Fonction : Auteur
Ming-Chien Shan
  • Fonction : Auteur
Business process automation technologies are being increasingly used by many companies to improve the efficiency of both internal processes as well as of e-services offered to customers. In order to satisfy customers and employees, business processes need to be executed with both high and predictable quality. In particular, it is crucial for organizations to meet the Service Level Agreements (SLAs) stipulated with the customers and to foresee as early as possible the risk of missing SLAs, in order to set the right expectations and to allow for corrective actions. In this paper we focus on a critical issue in business process quality: that of analyzing, predicting and preventing the occurrence of exceptions, i.e., of deviations from the desired or acceptable behavior. We characterize the problem and propose a solution, based on data warehousing and data mining techniques. We then describe the architecture and implementation of a tool suite that enables exception analysis, prediction, and prevention. Finally, we show experimental results obtained by using the tool suite to analyze internal HP processes.
Autre [cs.OH]
Fichier non déposé
inria-00100410 , version 1 (26-09-2006)
  • HAL Id : inria-00100410 , version 1
Daniela Grigori, Fabio Casati, Umesh Dayal, Ming-Chien Shan. Improving Business Process Quality through Exception Understanding, Prediction, and Preventing. Proceedings of 27th International Conference on Very Large Data Bases - VLDB'2001, Sep 2001, Roma, Italy, 10 p. ⟨inria-00100410⟩
59 Consultations
0 Téléchargements
