Visual Salience and Perceptual Grouping in Multimodal Interactivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
This paper deals with the pragmatic interpretation of multimodal referring expressions in man-machine dialogue systems. We show the importance of building up a structure of the visual context at a semantic level, in order to enrich the significant possibilities of interpretations and to make possible the fusion of this structure with the ones obtained from the linguistic and gesture semantic analyses. Visual salience and perceptual grouping are two notions that guide such a structuring. We thus propose a hierarchy of salience criteria linked to an algorithm that detects salient objects, as well as guidelines for grouping algorithms. We show how the integration of the results of all these algorithms is a complex problem. We propose simple heuristics to reduce this complexity and we conclude on the usability of such heuristics in actual systems.
Fichier non déposé
inria-00100576 , version 1 (26-09-2006)
inria-00100576 , version 2 (07-11-2006)
  • HAL Id : inria-00100576 , version 1
Frédéric Landragin, Nadia Bellalem, Laurent Romary. Visual Salience and Perceptual Grouping in Multimodal Interactivity. Workshop on Information Presentation and Natural Multimodal Dialogue, 2001, Verona, Italy, 5 p. ⟨inria-00100576v1⟩
445 Consultations
448 Téléchargements
