Time Constrained Communication Over Switched Ethernet - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Ye-Qiong Song
There is a growing interest of using switched Ethernet to support time constrained communication required by process control, factory automation and other real-time applications. Although many special-purposed industrial solutions have been proposed, it still lacks of some general quantitative evaluation of the real-time handling capability of a switched Ethernet. This paper first gives a comprehensive analysis of the interesting features offered by a switched Ethernet for supporting time constrained communication and then evaluates the performance of an Ethernet switch. The obtained analytic results can be considered as a basic knowledge for further verifying the total end to end response time guarantees (both hard real-time and soft real-time ones).
Fichier non déposé
inria-00100586 , version 1 (26-09-2006)
  • HAL Id : inria-00100586 , version 1
Ye-Qiong Song. Time Constrained Communication Over Switched Ethernet. 4th IFAC International Conference on Fieldbus Systems and their Applications - FeT'2001, LORIA et SEE, 2001, Nancy, France, 8 p. ⟨inria-00100586⟩
156 Consultations
0 Téléchargements
