A Common XML-based Framework for Syntactic Annotations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
It is widely recognized that the proliferation of annotation schemes runs counter to the need to re-use language resources, and that standards for linguistic annotation are becoming increasingly mandatory. To answer this need, we have developed a framework comprised of an abstract model for a variety of different annotation types (e.g., morpho-syntactic tagging, syntactic annotation, co-reference annotation, etc.), which can be instantiated in different ways depending on the annotator's approach and goals. In this paper we provide an overview of the framework, demonstrate its applicability to syntactic annotation, and show how it can contribute to comparative evaluation of parser output and diverse syntactic annotation schemes.
xmlnlp-sub.pdf (131.94 Ko) Télécharger le fichier
inria-00100592 , version 1 (14-09-2009)
  • HAL Id : inria-00100592 , version 1
  • ARXIV : 0909.2718
Nancy Ide, Laurent Romary, Tomaz Erjavec. A Common XML-based Framework for Syntactic Annotations. 1st NLP and XML Workshop, Nov 2001, Tokyo, Japan, Japan. ⟨inria-00100592⟩
163 Consultations
90 Téléchargements
