A Design Pattern for Connection Management in Herarchical Dynamic Virtual Private Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
In this paper we address the architecture of an efficient connection manager in hierarchical dynamic virtual private networks (HDVPN). HDVPNs encapsulate the delivery over a WAN of concurrent multicast sessions with security and QoS guarantees. Their main feature is a high degree of change in terms of membership, implying the necessity for fast reconfiguration and provisioning. We propose a Management Configuration Component based on already proven design patterns in order to cope with the high dynamicity encountered. The more general framework is the management of residential user TV multicast, where an heterogeneous ATM/IP based network supports the delivery of TV content to all clients having subscribed to a HDVPN.
Autre [cs.OH]
Fichier non déposé
inria-00100624 , version 1 (26-09-2006)
  • HAL Id : inria-00100624 , version 1
Radu State, Olivier Festor, Emmanuel Nataf. A Design Pattern for Connection Management in Herarchical Dynamic Virtual Private Networks. 8th IEEE International Conference on Telecommunications - ICT'2001, Jun 2001, Bucarest, Romania, 6 p. ⟨inria-00100624⟩
80 Consultations
0 Téléchargements
