Implementation of SNMP Agent for New version Internet protocol IPv6
This document presents the implementation of some tables of the "unified" MIB II for IPv6 and IPv4 networks. It explicitly describes how to implement a new MIB table into a net-snmp package, and explains the implementation done for the InetNetToMedia table, the inetIcmp table, the inetIcmpMsg table, the ipForward table, the TCP and UDP tables. For each of these implementations, it tells which kernel function should be used, how to recover the information wanted and gives the requests output of the above tables, using SNMP. This was done on a FreeBsd 4.6 system. This work completes the ones made by Mongi Abdelmoula and Neha Jha. || Ce document présente l'implémentation de quelques tables de la MIB II "unifiée" pour les réseaux IPv6 et IPv4. Il décrit explicitement comment implémenter de nouvelles tables de MIB dans la fourniture net-snmp, et explique l'implémentation faite pour les
