Subquadratic computation of vector generating polynomials and improvement of the block Wiedemann algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2002
This paper describes a new algorithm for computing linear generators (vector generating polynomials) for matrix sequences, running in sub-quadratic time. This algorithm applies in particular to the sequential stage of Coppersmith's block Wiedemann algorithm. Experiments showed that our method can be substituted in place of the quadratic one proposed by Coppersmith, yielding important speedups even for realistic matrix sizes. The base fields we were interested in were finite fields of large characteristic. As an example, we have been able to compute a linear generator for a sequence of 4*4 matrices of length 242 304 defined over GF(2^607) in less than two days on one 667MHz alpha ev67 cpu.
jsc.pdf (236.2 Ko) Télécharger le fichier
inria-00103417 , version 1 (04-10-2006)
Emmanuel Thomé. Subquadratic computation of vector generating polynomials and improvement of the block Wiedemann algorithm. Journal of Symbolic Computation, 2002, 33 (5), pp.757-775. ⟨10.1006/jsco.2002.0533⟩. ⟨inria-00103417⟩
189 Consultations
1506 Téléchargements
