The Number of Lines Tangent to Arbitrary Convex Polyhedra in 3D - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We prove that the lines tangent to four possibly intersecting polytopes in $R3$ with $n$ edges in total form $\Theta(n^2)$ connected components. In the generic case, each connected component is a single line, but our result still holds for arbitrary degenerate scenes. This improves the previously known $O(n^3\log n)$ bound by Agarwal~\cite{A94}. More generally, we show that a set of $k$ polytopes with a total of $n$ edges admits, in the worse case, $\Theta(n^2k^2)$ connected components of lines tangent to any four of these polytopes.
p135-lazard.pdf (176.24 Ko) Télécharger le fichier
inria-00103995 , version 1 (19-11-2007)
Hervé Brönnimann, Olivier Devillers, Vida Dujmovic, Hazel Everett, Marc Glisse, et al.. The Number of Lines Tangent to Arbitrary Convex Polyhedra in 3D. Proceedings of the 20th Annual Symposium on Computational Geometry, Jun 2004, Brooklyn, NY, United States. pp.46 - 55, ⟨10.1145/997817.997827⟩. ⟨inria-00103995⟩
303 Consultations
179 Téléchargements
