A Lexicon Driven Method for Unconstrained Bangla Handwritten Word Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this paper a lexicon driven segmentationrecognition scheme for unconstrained Bangla handwritten word recognition is proposed for Indian postal automation. In the proposed method, at first, binarization of the input document is done and slant correction of the individual words is performed. Next, using water reservoir concept words are pre-segmented into possible primitive components (characters or its parts). In order to merge these primitive components into characters and to find optimum character segmentation, dynamic programming (DP) is applied using total likelihood of characters as the objective function. To compute the likelihood of a character, modified quadratic discriminant function (MQDF) is used for the purpose. The features used in the MQDF are mainly based on the directional features of the contour points of the components. We tested our system on Bangla city-name images and at present an overall accuracy of 87.21% is obtained from the proposed system.
cr1035210380410.pdf (316.23 Ko) Télécharger le fichier
inria-00104048 , version 1 (05-10-2006)
  • HAL Id : inria-00104048 , version 1
U. Pal, K. Roy, F. Kimura. A Lexicon Driven Method for Unconstrained Bangla Handwritten Word Recognition. Tenth International Workshop on Frontiers in Handwriting Recognition, Université de Rennes 1, Oct 2006, La Baule (France). ⟨inria-00104048⟩
Collections
IWFHR10
216 Consultations
264 Téléchargements
