Word-wise Hand-written Script Separation for Indian Postal automation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In a multi-lingual multi-script country like India, a postal document may contain words of two or more scripts. For recognition of this document it is necessary to separate different scripts from the document. In this paper, an automatic scheme for word-wise identification of hand-written Roman and Oriya scripts is proposed for Indian postal automation. In the proposed scheme, at first, document skew is corrected. Next, using a piecewise projection method the document is segmented into lines and then lines into words. Finally, using different features like, water reservoir concept based features, fractal dimension based features, topological features, scripts characteristics based features etc., a Neural Network (NN) classifier is used for word-wise script identification. For experiment we consider 2500 words and overall accuracy of 97.69% is obtained from the proposed identification scheme.
cr1065210301587.pdf (321.95 Ko) Télécharger le fichier
inria-00104358 , version 1 (06-10-2006)
  • HAL Id : inria-00104358 , version 1
K. Roy, U. Pal. Word-wise Hand-written Script Separation for Indian Postal automation. Tenth International Workshop on Frontiers in Handwriting Recognition, Université de Rennes 1, Oct 2006, La Baule (France). ⟨inria-00104358⟩
Collections
IWFHR10
113 Consultations
188 Téléchargements
