Merging Cellular Automata for Simulating Surface Effects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Denis Finck
  • Fonction : Auteur
  • PersonId : 835773
This paper describes a model of three-dimensional cellular automata allowing to simulate different phenomena in the fields of com- puter graphics and image processing, and to combine them together in order to produce complex effects such as automatic multitexturing, sur- face imperfections, or biological retina multi-layer cellular behaviours. Our cellular automaton model is defined as a network of connected cells arranged in a natural and dynamic way, which affords multi-behavior ca- pabilities. Based on cheap and widespread computing systems, real-time performance can be reached for simulations involving up to a hundred thousand cells. Our approach efficiency is illustrated through a set of CA related to computer graphics –e.g. erosion, sedimentation, or vegetal growing processes– and image analysis –e.g. pipeline retina simulation.
acri.pdf (863.86 Ko) Télécharger le fichier
inria-00104539 , version 1 (12-12-2008)
  • HAL Id : inria-00104539 , version 1
Stéphane Gobron, Denis Finck, Philippe Even, Bertrand Kerautret. Merging Cellular Automata for Simulating Surface Effects. 7th International Conference on Cellular Automata For Research and Industry - ACRI 2006, Sep 2006, Perpignan, France. pp.94-103. ⟨inria-00104539⟩
133 Consultations
324 Téléchargements
