A Monitoring Approach for Safe IPv6 Renumbering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Network renumbering is a very interesting feature of IPv6. It is also one of the most risky procedure which needs special attention in the management plane. In this paper we identify the challenges of renumbering and demonstrate how monitoring can improve this process. We also present an implementation of a monitoring framework and share the experience gained in its deployment.
Mots clés
article.pdf (125.23 Ko) Télécharger le fichier
inria-00106170 , version 1 (13-10-2006)
  • HAL Id : inria-00106170 , version 1
Frédéric Beck, Isabelle Chrisment, Olivier Festor. A Monitoring Approach for Safe IPv6 Renumbering. IPv6 Today - Technology and Deployment, Aug 2006, Bucharest/Romania. ⟨inria-00106170⟩
149 Consultations
197 Téléchargements
