A Tool for Lazy Verification of Security Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
We present the lazy strategy implemented in a compiler of cryptographic protocols, Casrul. The purpose of this compiler is to verify protocols and to translate them into rewrite rules that can be used by several kinds of automatic or semi-automatic tools for finding flaws, or proving properties. It is entirely automatic, and the efficiency of the generated rules is guaranteed because of the use of a lazy model of an Intruder behavior. This efficiency is illustrated on several examples.
A01-R-140.pdf (291 Ko) Télécharger le fichier
inria-00107545 , version 1 (19-10-2006)
  • HAL Id : inria-00107545 , version 1
Yannick Chevalier, Laurent Vigneron. A Tool for Lazy Verification of Security Protocols. [Intern report] A01-R-140 || chevalier01b, 2001, 10 p. ⟨inria-00107545⟩
92 Consultations
215 Téléchargements
