Object Programming in a Rule-Based Language with Strategies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
This paper presents a programming framework that combines the concepts of objects, rules and strategies, built as an extension of the rule-based language with strategies ELAN. This extension is implemented in a reflective way in ELAN itself and relies on the same formal semantics,namely the rewriting calculus.
A02-R-443.pdf (335.78 Ko) Télécharger le fichier
inria-00107615 , version 1 (19-10-2006)
  • HAL Id : inria-00107615 , version 1
Hubert Dubois, Hélène Kirchner. Object Programming in a Rule-Based Language with Strategies. Workshop on Multiparadigm Programming with OO Languages - ECOOP'02, Jun 2002, Malaga, Spain, 25 p. ⟨inria-00107615⟩
48 Consultations
44 Téléchargements
