Evaluating Quality of Service and Behavioral Reliability of Steer-by-Wire Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Steer-by-wire systems must meet not only reliability but also real-time requirements. This paper presents an integrated approach for evaluating both the temporal performance and the behavioral reliability of Steer-by-wire systems taking into account the delay variation introduced by network transmission errors. The considered temporal performance is the Quality of Service perceived by the user, i.e. the vehicle stability. Tests in vehicles and simulations have been realized to estimate the maximum tolerable response time of the system, and to evaluate the impact of this delay on the Quality of Service. We quantify then the worst case response time of the system for a generic architecture based on TDMA protocol but independent of the communication network (could actually be TTP/C or FlexRay), and apply these generic results to a case study. We further define the notion of behavioral reliability as the probability that the worst case response time is less than a threshold. In our case study this behavioral reliability is evaluated and linked to the Safety Integrity Levels defined in IEC61508-1 standard. Based on this behavioral reliability concept, the final objective of our work is to propose a new dependability analysis method for X-by-Wire systems by taking into account both dynamic performance, fault-tolerance mechanisms and static redundancy of the system . || Les systèmes de direction électronique (steer-by-Wire) doivent respecter des contraintes à la fois de fiabilité et de temps réel. Ce papier présente une approche intégrée pour évaluer à la fois les performances temporelles et la fiabilité comportementale
Autre [cs.OH]
A03-R-297.pdf (297.28 Ko) Télécharger le fichier
inria-00107701 , version 1 (19-10-2006)
  • HAL Id : inria-00107701 , version 1
Cédric Wilwert, Ye-Qiong Song, Françoise Simonot-Lion, Thomas Clément. Evaluating Quality of Service and Behavioral Reliability of Steer-by-Wire Systems. 9th IEEE International Conference on Emerging Technologies and Factory Automation -EFTA'2003, 2003, Lisbonne, Portugal, pp.193-200. ⟨inria-00107701⟩
106 Consultations
229 Téléchargements
