Managing concurrent QoS assured Multicast sessions using a Programmable Network Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
In this paper we address the management of concurrent multicast sessions with security and QoS guarantees. Their main feature is a high degree of change in terms of membership, implying the necessity for fast reconfiguration and provisioning. We will approach the management problem using techniques developed in the context of virtual private networks, adapted to the high dynamicity that we are confronted with. We propose a framework for the management of such networks by integrating the management and the control plane, using the programmable and active networks paradigms developed within the research community. We apply the framework to the management of residential user TV multicast, where an ATM based access network supports the delivery of TV content to all clients having subscribed to a DVPN.
Autre [cs.OH]
A00-R-151.pdf (296.75 Ko) Télécharger le fichier
inria-00107851 , version 1 (19-10-2006)
  • HAL Id : inria-00107851 , version 1
Radu State, Olivier Festor, Emmanuel Nataf. Managing concurrent QoS assured Multicast sessions using a Programmable Network Architecture. 11th IFIP/IEEE International Workshop on Distributed Systems: Operations & Management - DSOM'2000, IEEE, Dec 2000, USA, 12 p. ⟨inria-00107851⟩
82 Consultations
73 Téléchargements
