HMM-Based On-Line Recognition of Handwritten Whiteboard Notes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this paper we present an on-line recognition system for handwritten texts acquired from a whiteboard. This input modality has received relatively little attention in the handwriting recognition community in the past. The system proposed in this paper uses state-of-the-art normalization and feature extraction strategies to transform a handwritten text line into a sequence of feature vectors. Additional preprocessing techniques are introduced, which significantly increase the word recognition rate. For classification, Hidden Markov Models are used together with a statistical language model. In writer independent experiments we achieved word recognition rates of 67.3% on the test set when no language model is used, and 70.8% by including a language model.
cr1024111513799.pdf (164.67 Ko) Télécharger le fichier
inria-00108307 , version 1 (20-10-2006)
  • HAL Id : inria-00108307 , version 1
Marcus Liwicki, Horst Bunke. HMM-Based On-Line Recognition of Handwritten Whiteboard Notes. Tenth International Workshop on Frontiers in Handwriting Recognition, Université de Rennes 1, Oct 2006, La Baule (France). ⟨inria-00108307⟩
Collections
IWFHR10
393 Consultations
935 Téléchargements
