Embedded Powerline Communication in Large Scale Distribution Automation and Demand Side Management System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Implementation of Distribution Automation (DA) and Demand Side Management (DSM) intended to serve both utilities and a large number of customers which spread over a large geographical area, requires a wide-area two-way communication system. DA and DSM devices (customer meters, switches, etc.), embedded with Powerline communication, can use the powerline as a communication medium, to construct a cost-effective and high speed transmission communication network. REMPLI project aims at designing and implementing a communication infrastructure for distributed data acquisition and remote control operation using the power grid as the communication medium. In this paper, we evaluate the REMPLI PLC network performance to show how the requirements for both DA/DSM applications can be met. And a scheduling policy is proposed to provide the applications with differentiate QoS in a multitasking environment.
PID266076.pdf (231.92 Ko) Télécharger le fichier
inria-00113782 , version 1 (14-11-2006)
  • HAL Id : inria-00113782 , version 1
Liping Lu, Jianhua Zhou, Jian Hu, Gangyan Li, Ye-Qiong Song. Embedded Powerline Communication in Large Scale Distribution Automation and Demand Side Management System. The 2nd IEEE/ASME International Conference on Mechatronic and Embedded Systems and Applications, Aug 2006, Beijing, China. ⟨inria-00113782⟩
128 Consultations
451 Téléchargements
