DIET: New Developments and Recent Results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Among existing grid middleware approaches, one simple, powerful, and flexible approach consists of using servers available in different administrative domains through the classic client-server or Remote Procedure Call (RPC) paradigm. Network Enabled Servers (NES) implement this model also called GridRPC. Clients submit computation requests to a scheduler whose goal is to find a server available on the grid. The aim of this paper is to give an overview of an NES middleware developed in the GRAAL team called DIET and to describe recent developments. DIET (Distributed Interactive Engineering Toolbox) is a hierarchical set of components used for the development of applications based on computational servers on the grid.
RR-diet-coregrid.pdf (633.9 Ko) Télécharger le fichier
inria-00115569 , version 1 (22-11-2006)
inria-00115569 , version 2 (23-11-2006)
inria-00115569 , version 3 (25-11-2006)
  • HAL Id : inria-00115569 , version 1
Abdelkader Amar, Raphaël Bolze, Aurélien Bouteiller, Andréea Chis, Yves Caniou, et al.. DIET: New Developments and Recent Results. [Research Report] 2006, pp.24. ⟨inria-00115569v1⟩
360 Consultations
323 Téléchargements
