Hierarchical Finite-State Modeling for Texture Segmentation with Application to Forest Classification - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2006
In this research report we present a new model for texture representation which is particularly well suited for image analysis and segmentation. Any image is first discretized and then a hierarchical finite-state region-based model is automatically coupled with the data by means of a sequential optimization scheme, namely the Texture Fragmentation and Reconstruction (TFR) algorithm. The TFR algorithm allows to model both intra- and inter-texture interactions, and eventually addresses the segmentation task in a completely unsupervised manner. Moreover, it provides a hierarchical output, as the user may decide the scale at which the segmentation has to be given. Tests were carried out on both natural texture mosaics provided by the Prague Texture Segmentation Datagenerator Benchmark and remote-sensing data of forest areas provided by the French National Forest Inventory (IFN).
RR-6066.pdf (2.19 Mo) Télécharger le fichier
Dates and versions
inria-00118420 , version 1 (11-12-2006)
inria-00118420 , version 2 (18-12-2006)
Identifiers
  • HAL Id : inria-00118420 , version 2
Cite
Giuseppe Scarpa, Michal Haindl, Josiane Zerubia. Hierarchical Finite-State Modeling for Texture Segmentation with Application to Forest Classification. [Research Report] RR-6066, INRIA. 2006, pp.47. ⟨inria-00118420v2⟩
204 View
197 Download
Share
