Hierarchical Finite-State Modeling for Texture Segmentation with Application to Forest Classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
In this research report we present a new model for texture representation which is particularly well suited for image analysis and segmentation. Any image is first discretized and then a hierarchical finite-state region-based model is automatically coupled with the data by means of a sequential optimization scheme, namely the Texture Fragmentation and Reconstruction (TFR) algorithm. The TFR algorithm allows to model both intra- and inter-texture interactions, and eventually addresses the segmentation task in a completely unsupervised manner. Moreover, it provides a hierarchical output, as the user may decide the scale at which the segmentation has to be given. Tests were carried out on both natural texture mosaics provided by the Prague Texture Segmentation Datagenerator Benchmark and remote-sensing data of forest areas provided by the French National Forest Inventory (IFN).
RR-6066.pdf (2.19 Mo) Télécharger le fichier
inria-00118420 , version 1 (11-12-2006)
inria-00118420 , version 2 (18-12-2006)
  • HAL Id : inria-00118420 , version 2
Giuseppe Scarpa, Michal Haindl, Josiane Zerubia. Hierarchical Finite-State Modeling for Texture Segmentation with Application to Forest Classification. [Research Report] RR-6066, INRIA. 2006, pp.47. ⟨inria-00118420v2⟩
211 Consultations
211 Téléchargements
