Mechanical Theorem Proving in Tarski's geometry. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper describes the mechanization of the proofs of the first height chapters of Schwabäuser, Szmielew and Tarski's book: Metamathematische Methoden in der Geometrie. The goal of this development is to provide foundations for other formalizations of geometry and implementations of decision procedures. We compare the mechanized proofs with the informal proofs. We also compare this piece of formalization with the previous work done about Hilbert's Gründlagen der Geometrie. We analyze the differences between the two axiom systems from the formalization point of view.
adg06-narboux.pdf (238.19 Ko) Télécharger le fichier
inria-00118812 , version 1 (06-12-2006)
Julien Narboux. Mechanical Theorem Proving in Tarski's geometry.. Automated Deduction in Geometry 2006, Francisco Botana, Aug 2006, Pontevedra, Spain. pp.139-156, ⟨10.1007/978-3-540-77356-6⟩. ⟨inria-00118812⟩
407 Consultations
469 Téléchargements
