Explicit factors of some iterated resultants and discriminants - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2006
Laurent Busé
Bernard Mourrain
In this paper, we analyze the result of applying iterative univariate resultant constructions to multivariate polynomials. We consider the input polynomials as generic polynomials of a given degree and exhibit explicit decomposition into irreducible factors of several constructions involving two times iterated univariate resultants and discriminants over the integer universal ring of coefficients of the entry polynomials. Cases involving from two to four generic polynomials and resultants or discriminants in one of their variables are treated. The decompositions into irreducible factors we get are obtained by exploiting fundamental properties of the univariate resultants and discriminants and induction on the degree of the polynomials. As a consequence, each irreducible factor can be separately and explicitly computed in terms of a certain multivariate resultant. With this approach, we also obtain as direct corollaries some results conjectured by Collins (1975) and McCallum (1999) which corresponds to the case of polynomials whose coefficients are themselves generic polynomials in other variables. Finally, a geometric interpretation of the algebraic factorization of the iterated discriminant of a single polynomial is detailled.
iterres.pdf (423.44 Ko) Télécharger le fichier
inria-00119287 , version 1 (08-12-2006)
inria-00119287 , version 2 (15-10-2007)
Laurent Busé, Bernard Mourrain. Explicit factors of some iterated resultants and discriminants. 2006. ⟨inria-00119287v1⟩
380 Consultations
222 Téléchargements
