Application des machines a vecteurs support mono-classe a l'indexation en locuteurs de documents audio - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Belkacem Fergani
  • Fonction : Auteur
Amrane Houacine
  • Fonction : Auteur
This paper addresses a new approach based on the Kernel Change Detection algorithm introduced recently by Desobry et al. This new algorithm is applied to the speaker change detection and clustering tasks, which are the key issues in any audio indexing process. We show the efficiency of the method through several experiments using RT'03S NIST data. We discuss also the parameters tuning and compare the results to the well known GLR-BIC algorithm.
final-28.pdf (86.3 Ko) Télécharger le fichier
inria-00119998 , version 1 (12-12-2006)
  • HAL Id : inria-00119998 , version 1
Belkacem Fergani, Manuel Davy, Amrane Houacine. Application des machines a vecteurs support mono-classe a l'indexation en locuteurs de documents audio. Journees d'Etude sur la Parole 2006, 2006, Dinard, France. ⟨inria-00119998⟩
140 Consultations
300 Téléchargements
