HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
An Effective Stratified Sampling Scheme for Environment Maps with Median Cut Method.
Abstract : Environment maps are extensively used as natural light sources in realistic rendering. We propose a stratified sampling scheme for environment maps by first stratifying the maps into a set of rectangular regions with Median Cut method, then estimating the contribution of the regions with Monte Carlo integration techniques. In this way, illumination, surface reflectance and spatial distribution are all taken into consideration for the generation of the light samples. Compared with the existing biased lighting techniques, the presented scheme produces unbiased rendering results with less noise and better shadow boundaries, particularly at low sampling rates. The proposed spatial distribution of the samples also helps to overcome the sampleclumping problem in traditional illumination-based importance sampling method. Experimental results indicate that the scheme is fast, simple to implement and effective
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00122644
Contributor : Chine Publications Liama Connect in order to contact the contributor
Submitted on : Thursday, January 4, 2007 - 10:57:07 AM
Last modification on : Friday, October 22, 2021 - 9:19:44 AM
Links full text
Identifiers
Citation
Xing Mei, Marc Jaeger, Bao-Gang Hu. An Effective Stratified Sampling Scheme for Environment Maps with Median Cut Method.. Third International Conference on Computer Graphics, Imagingand Visualization (CGIV 2006),, 2006, Sydney / Australie, France. pp.384-389, ⟨10.1109/CGIV.2006.19⟩. ⟨inria-00122644⟩
Share
Metrics
Record views
380
