Intensity-Based Robust Similarity for Multimodal Image Registration, International Journal of Computer Mathematics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Mathematics Année : 2006
This paper proposes a new intensity-based similarity metric that can be used for the registration of multimodal images. It combines the robust estimation with both the forward and inverse transformation to reduce the negative effects of outliers in the images. For this purpose, we firstly employ the multiresolution technique to downsample the original images, then resort to the simulated annealing method to initialize the transformation parameters at the coarsest resolution. Finally the Powell method is utilized to obtain the optimal transformation parameters at each resolution. In our experiments, the new method is compared to other popular similarity measures, on the synthetic data as well as the real data, and the experimental results are encouraging.
Fichier non déposé
inria-00123833 , version 1 (11-01-2007)
Juan Du, Songyuan Tang, Tianzi Jiang, Zhensu Lu. Intensity-Based Robust Similarity for Multimodal Image Registration, International Journal of Computer Mathematics. International Journal of Computer Mathematics, 2006, International Journal of Computer Mathematics, 38 (1), pp.49-57. ⟨10.1080/00207160500112944⟩. ⟨inria-00123833⟩
86 Consultations
0 Téléchargements
