Concurrency in Synchronous Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Formal Methods in System Design Année : 2006
In this paper we introduce the notion of weak endochrony, which extends to a synchronous setting the classical theory of Mazurkiewicz traces. The notion is useful in the synthesis of correct-by-construction communication protocols for globally asynchronous, locally synchronous (GALS) systems. The independence between various computations can be exploited here to provide communication schemes that do not restrict concurrency while still guaranteeing correctness. Such communication schemes are then lighter and more flexible than their latency-insensitive or endo/isochronous counterparts.
potop-et-al-fmsd-2006.pdf (418.88 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
inria-00124252 , version 1 (01-03-2007)
Dumitru Potop-Butucaru, Benoit Caillaud, Albert Benveniste. Concurrency in Synchronous Systems. Formal Methods in System Design, 2006, 28 (2), pp.111-130. ⟨10.1007/s10703-006-7844-8⟩. ⟨inria-00124252⟩
220 Consultations
186 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
