Mining Biomedical Texts to Generate Semantic Annotations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This report focuses on text mining in the biomedical domain for the generation of semantic annotations based on a formal model which is ontology. We start by exposing the generic methodology for the generation of annotations from texts. Then, we present a state of the art on different knowledge extraction techniques used on biomedical texts. We propose our approach based on Semantic Web Technologies and Natural Language Processing (NLP): it relies on formal ontologies to generate semantic annotations on scientific articles and on other knowledge sources (databases, experiment sheets). This approach can be extended to other do-mains requiring experiments and massive data analyses. Finally, we conclude with a discussion about our work and we present some learnt lessons.
RR-6102.pdf (469.73 Ko) Télécharger le fichier
inria-00125266 , version 1 (18-01-2007)
inria-00125266 , version 2 (22-01-2007)
inria-00125266 , version 3 (22-01-2007)
  • HAL Id : inria-00125266 , version 2
Khaled Khelif, Rose Dieng-Kuntz, Pascal Barbry. Mining Biomedical Texts to Generate Semantic Annotations. [Research Report] RR-6102, 2007. ⟨inria-00125266v2⟩
Collections
INRIA-RRRT
200 Consultations
241 Téléchargements
