A New Self-Stabilizing Maximal Matching Algorithm
Fredrik Manne 1 Morten Mjelde 1 Laurence Pilard 2 Sébastien Tixeuil 3, 4
4 GRAND-LARGE - Global parallel and distributed computing
CNRS - Centre National de la Recherche Scientifique : UMR8623, Inria Saclay - Ile de France, UP11 - Université Paris-Sud - Paris 11, LIFL - Laboratoire d'Informatique Fondamentale de Lille, LRI - Laboratoire de Recherche en Informatique
Abstract : The maximal matching problem has received considerable attention in the self-stabilizing community. Previous work has given different self-stabilizing algorithms that solves the problem for both the adversarial and fair distributed daemon, the sequential adversarial daemon, as well as the synchronous daemon. In the following we present a single self-stabilizing algorithm for this problem that unites all of these algorithms in that it stabilizes in the same number of moves as the previous best algorithms for the sequential adversarial, the distributed fair, and the synchronous daemon. In addition, the algorithm improves the previous best moves complexities for the distributed adversarial daemon from O(n^2) and O(delta m) to O(m) where n is the number of processes, m is thenumber of edges, and delta is the maximum degree in the graph.
Type de document :
Rapport
[Research Report] RR-6111, INRIA. 2007, pp.17
Liste complète des métadonnées
Littérature citée [12 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00127899
Contributeur : Rapport de Recherche Inria <>
Soumis le : mardi 6 février 2007 - 10:28:57
Dernière modification le : lundi 16 juillet 2018 - 18:36:03
Document(s) archivé(s) le : mardi 21 septembre 2010 - 12:35:07
Fichiers
RR-6111.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00127899, version 2
  • ARXIV : cs/0701189
Collections
Citation
Fredrik Manne, Morten Mjelde, Laurence Pilard, Sébastien Tixeuil. A New Self-Stabilizing Maximal Matching Algorithm. [Research Report] RR-6111, INRIA. 2007, pp.17. 〈inria-00127899v2〉
Métriques
Consultations de la notice
264
Téléchargements de fichiers
243
