A First Step Towards Automatically Building Network Representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
To fully harness Grids, users or middlewares must have some knowledge on the topology of the platform interconnection network. As such knowledge is usually not available, one must uses tools which automatically build a topological network model through some measurements. In this article, we define a methodology to assess the quality of these network model building tools, and we apply this methodology to representatives of the main classes of model builders and to two new algorithms. We show that none of the main existing techniques build models that enable to accurately predict the running time of simple application kernels for actual platforms. However some of the new algorithms we propose give excellent results in a wide range of situations.
RR-6133.pdf (200.56 Ko) Télécharger le fichier
inria-00130734 , version 1 (13-02-2007)
inria-00130734 , version 2 (26-02-2007)
inria-00130734 , version 3 (28-06-2007)
Lionel Eyraud-Dubois, Arnaud Legrand, Martin Quinson, Frédéric Vivien. A First Step Towards Automatically Building Network Representations. [Research Report] RR-6133, 2007. ⟨inria-00130734v2⟩
Collections
INRIA-RRRT
581 Consultations
350 Téléchargements
