Hybrid MPI-Thread Parallelization of the Fast Multipole Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We present in this paper multi-thread and multi-process parallelizations of the Fast Multipole Method (FMM) for Laplace equation, for uniform and non uniform distributions. These parallelizations apply to the original FMM formulation and to our new matrix formulation with BLAS (Basic Linear Algebra Subprograms) routines. Differences between the multi-thread and the multi-process versions are detailed, and a hybrid MPI-thread approach enables to gain parallel efficiency and memory scalability over the pure MPI one on clusters of SMP nodes. On 128 processors, we obtain 85% (respectively 75%) parallel efficiency for uniform (respectively non uniform) distributions with up to 100 million particles.
ISPDC07_CoulaudFortinRoman.pdf (165.16 Ko) Télécharger le fichier
inria-00131001 , version 1 (14-02-2007)
inria-00131001 , version 2 (16-07-2007)
  • HAL Id : inria-00131001 , version 2
Olivier Coulaud, Pierre Fortin, Jean Roman. Hybrid MPI-Thread Parallelization of the Fast Multipole Method. ISPDC 2007, 6th International Symposium on Parallel and Distributed Computing, Jul 2007, Hagenberg, Austria, Australia. pp.391-398. ⟨inria-00131001v2⟩
249 Consultations
373 Téléchargements
