Design of a pressure control system with dead band and time delay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Control Systems Technology Année : 2007
This paper investigates the control of pressure in a hydraulic circuit containing a dead band and a time varying delay. The dead band is considered as a linear term and a perturbation. A sliding mode controller is designed. Stability conditions are established by making use of Lyapunov Krasovskii functionals, non-perfect time delay estimation is studied and a condition for the effect of uncertainties on the dead zone on stability is derived. Also the effect of different LMI formulations on conservativeness is studied. The control law is tested in practice.
Anthonis_et_al_IEEE_CST07.pdf (232.82 Ko) Télécharger le fichier
inria-00131415 , version 1 (16-02-2007)
Jan Anthonis, Alexandre Seuret, Jean-Pierre Richard, Herman Ramon. Design of a pressure control system with dead band and time delay. IEEE Transactions on Control Systems Technology, 2007, 15 (6), pp.1103 - 1111. ⟨10.1109/TCST.2006.890299⟩. ⟨inria-00131415⟩
430 Consultations
2619 Téléchargements
