On Dead Path Elimination in Decentralized Process Executions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ustun Yildiz
  • Fonction : Auteur
  • PersonId : 830461
Dead Path Elimination (DPE) is a particular operation supported by most workflow management systems. This report presents a novel approach to fulfill DPE in decentralized process executions.
RR-no-numero-yet.pdf (992.41 Ko) Télécharger le fichier
inria-00132928 , version 1 (23-02-2007)
inria-00132928 , version 2 (26-02-2007)
  • HAL Id : inria-00132928 , version 1
Ustun Yildiz. On Dead Path Elimination in Decentralized Process Executions. [Research Report] 2007, pp.31. ⟨inria-00132928v1⟩
117 Consultations
174 Téléchargements
