Abstract : The problem of predicting the occurrences of a pattern in a partially-observed discrete-event system is studied. The system is modeled by a labeled transition system. The pattern is a set of event sequences modeled by a finite-state automaton. The occurrences of the pattern are predictable if it is possible to infer about any occurrence of the pattern before the pattern is completely executed by the system. An off-line algorithm to verify the property of predictability is presented. The verification is polynomial in the number of states of the system. An on-line algorithm to track the execution of the pattern during the operation of the system is also presented. This algorithm is based on the use of a diagnoser automaton. The result are illustrated using an example from computer systems.
https://hal.inria.fr/inria-00136129 Contributor : Anne JaiguConnect in order to contact the contributor Submitted on : Monday, March 12, 2007 - 3:06:01 PM Last modification on : Friday, February 4, 2022 - 3:17:51 AM Long-term archiving on: : Wednesday, April 7, 2010 - 1:32:26 AM
