Parameter estimation via differential algebra and operational culculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Parameter estimation is approached via a new standpoint, based on differential algebra and operational calculus. Some applications such as, the estimation of a noisy damped sinusoid, the analysis of chirp signal, the detection of piecewise polynomial signals and their discontinuities are presented with numerical simulations.
estimalg.pdf (406.2 Ko) Télécharger le fichier
inria-00138294 , version 1 (25-03-2007)
  • HAL Id : inria-00138294 , version 1
Mamadou Mboup. Parameter estimation via differential algebra and operational culculus. [Research Report] 2007, pp.40. ⟨inria-00138294⟩
312 Consultations
524 Téléchargements
