A hp-like discontinuous Galerkin method for solving the 2D time-domain Maxwell's equations on non-conforming locally refined triangular meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work is concerned with the design of a hp-like discontinuous Galerkin (DG) method for solving the 2D time-domain Maxwell's equations on non-conforming locally refined triangular meshes. The proposed DG method allows non-conforming meshes with arbitrary-level hanging nodes. This method combines a centered approximation for the evaluation of fluxes at the interface between neighboring elements of the mesh, with a leap-frog time integration scheme.
hp_maxdg.pdf (1.65 Mo) Télécharger le fichier
inria-00140783 , version 1 (10-04-2007)
inria-00140783 , version 2 (29-05-2007)
  • HAL Id : inria-00140783 , version 1
Hassan Fahs, Stephane Lanteri, Francesca Rapetti. A hp-like discontinuous Galerkin method for solving the 2D time-domain Maxwell's equations on non-conforming locally refined triangular meshes. [Research Report] RR-6162, 2007, pp.44. ⟨inria-00140783v1⟩
Collections
INRIA-RRRT
513 Consultations
85 Téléchargements
