Reports
Decision Diagrams for Qualitative Biological Models
Michel Le Borgne 1 Philippe Veber 1
1 SYMBIOSE - Biological systems and models, bioinformatics and sequences
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : The modelisation of large biological systems such that metabolic networks or gene interaction networks, implies interpretations of heterogeneous biological knownledge. A common feature of observations accumulated by biologist on these systems is their qualitative nature. More over it often happens that the knownledge is based on comparisons between different experimental conditions. In previous papers variations in observed variables between two conditions was interpreted in terms of equilibria shift. This leads to use qualitative equations in a sign algebra. The present report gives details on the implementation and main algorithms involved.
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/inria-00144597
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Monday, October 29, 2007 - 4:02:30 PM
Last modification on : Friday, February 4, 2022 - 3:25:13 AM
Long-term archiving on: : Tuesday, September 21, 2010 - 2:56:57 PM
RR-6182.pdf
Identifiers
  • HAL Id : inria-00144597, version 2
Citation
Michel Le Borgne, Philippe Veber. Decision Diagrams for Qualitative Biological Models. [Research Report] RR-6182, INRIA. 2007, pp.17. ⟨inria-00144597v2⟩
Share
Metrics
Record views
112
Files downloads
105
