Web-Services Coordination Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Schahram Dustdar
  • Fonction : Auteur
Web-services are self-contained, self-describing modular applications and can be seen as a newly emerging distributed computing model for the Web. There are two types of web-services: atomic and composite. A composite Web-Service can be described as a directed process graph that composes other atomic or composite Web-Services. A graph defines the order of execution among the nodes in the process model. In this paper we first discuss the relevant research issues required for outlining a web-service coordination model and compare them to existing coordination models. Furthermore we provide an e-learning scenario where we experiment with a team-enabled workflow management system to enact workflow-based web-services.
Fichier non déposé
inria-00147550 , version 1 (18-05-2007)
  • HAL Id : inria-00147550 , version 1
Karim Baïna, Schahram Dustdar. Web-Services Coordination Model. Second International Workshop on Cooperative Internet Computing, in cooperation with VLDB 2002 - CIC'2002, Hong Kong Polytechnic University, 2002, Hong Kong, China, 13 p. ⟨inria-00147550⟩
57 Consultations
0 Téléchargements
