Fine-Tuning MAC-Level Protocols for Optimized Real-Time Quality-of-Service - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mathieu Grenier
  • Fonction : Auteur
  • PersonId : 830598
Nicolas Navet
  • Fonction : Auteur
  • PersonId : 830599
In distributed real-time systems, meeting the real-time constraints is mandatory but the satisfaction of other application-dependent criteria is most generally required as well. In particular, Networked Control Systems (NCS) are known to be sensitive to communication delays such as frame response time jitters. Well known Medium Access Control (MAC) algorithms such Non-Preemptive Deadline Monotonic (NP-DM) or Non-Preemptive Earliest Deadline First (NP-EDF) are efficient in terms of bandwidth usage but they may perform poorly regarding other application dependent performance criteria. This paper highlights a class of on-line scheduling policies targeted at scheduling frames at the MAC level, and provides a schedulability analysis that is valid for all policies within the considered class. As it will be shown, these algorithms are easily implementable on COTS components (e.g., Controller Area Network controllers) and offer good trade-offs between feasibility and the satisfaction of other application-dependent criteria such as the response time jitter.
RR-6247.pdf (498.44 Ko) Télécharger le fichier
inria-00158172 , version 1 (28-06-2007)
inria-00158172 , version 2 (18-07-2007)
inria-00158172 , version 3 (20-07-2007)
  • HAL Id : inria-00158172 , version 2
Mathieu Grenier, Nicolas Navet. Fine-Tuning MAC-Level Protocols for Optimized Real-Time Quality-of-Service. [Research Report] RR-6247, 2007, pp.22. ⟨inria-00158172v2⟩
Collections
INRIA-RRRT
123 Consultations
108 Téléchargements
