New algorithm for solving variational problems in $W^{1,p}\SO$ and $BV\SO$: Application to image restoration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Gilles Aubert
  • Fonction : Auteur
  • PersonId : 841269
Pierre Kornprobst
We propose a new unifying method for solving variational problems defined on the Sobolev spaces $W^{1,p}(\Omega)$ or on the space of functions of bounded variations $BV(\Omega)$ ($\Omega\subset\R^N$). The method is based on a recent new characterization of these spaces by Bourgain, Brezis and Mironescu (2001), where norms can be approximated by a sequence of integral operators involving a differential quotient and a suitable sequence of radial mollifiers. We use this characterization to define a variational formulation, for which existence, uniqueness and convergence of the solution is proved. The proposed approximation is valid for any $p$ and does not depend on the attach term. Implementation details are given and we show examples on the image restoration problem.
RR-6245.pdf (408.83 Ko) Télécharger le fichier
inria-00161706 , version 1 (11-07-2007)
inria-00161706 , version 2 (13-07-2007)
inria-00161706 , version 3 (13-07-2007)
inria-00161706 , version 4 (13-07-2007)
inria-00161706 , version 5 (26-07-2007)
  • HAL Id : inria-00161706 , version 2
Gilles Aubert, Pierre Kornprobst. New algorithm for solving variational problems in $W^{1,p}\SO$ and $BV\SO$: Application to image restoration. [Research Report] RR-6245, 2007, pp.28. ⟨inria-00161706v2⟩
Collections
INRIA-RRRT
168 Consultations
129 Téléchargements
