Asymptotic analysis for the solution to the Helmholtz problem in the exterior of a finite thin straight wire - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this document we are interested in the solution of the Helmholtz equation with Dirichlet boundary condition in the exterior of a thin elongated body. We suppose that the geometry is well described in ellipsoidal coordinates. We propose an asymptotic analysis of this problem, using matched expansions. This leads to the construction of an approximate field with more explicit expression. The approximate field is composed of the first terms of the asymptotic expansion of the exact solution. Our study also leads to a validation of an acoustic version of the Pocklington's equation.
RR-6277.pdf (534.88 Ko) Télécharger le fichier
inria-00163230 , version 1 (17-07-2007)
inria-00163230 , version 2 (03-09-2007)
inria-00163230 , version 3 (12-09-2007)
inria-00163230 , version 4 (10-12-2007)
  • HAL Id : inria-00163230 , version 2
Xavier Claeys. Asymptotic analysis for the solution to the Helmholtz problem in the exterior of a finite thin straight wire. [Research Report] RR-6277, 2007. ⟨inria-00163230v2⟩
Collections
ENSTA INRIA-RRRT
185 Consultations
878 Téléchargements
