Invariant image descriptors and affine morphological scale-space
In this research report we propose a novel approach to build interest points and descriptors which are invariant to a subclass of affine transformations. Scale and rotation invariant interest points are usually obtained via the linear scale-space representation, and it has been shown that affine invariance can be achieved by warping the smoothing kernel to match the local image structure. Our approach is instead based on the so-called Affine Morphological Scale-Space, a non-linear filtering which has been proved to be the natural equivalent of the classic linear scale-space when affine invariance is required. Simple local image descriptors are then derived from the extracted interest points. We demonstrate the proposed approach by robust matching experiments.
