OptimAX: optimizing distributed continuous queries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The system we propose to present, OptiMAX, applies the principles of distributed query optimization to the problem of distributed evaluation of continuous XML queries. OptiMAX is an optimizer for Active XML documents (AXML in short). It is implemented as a module which can be used next to an AXML peer, and it may be invoked whenever users ask queries on their AXML documents. The optimizer draws up an initial query plan, and then attempts to rewrtite it using a combination of heuristics and cost information in order to improve the plan's performance estimates. An interesting feature is that all plans are AXML documents themselves. When the optimizer has retained a plan, it hands it to the AXML peer, which evaluates it directly following the decisions taken by the optimizer.
Mots clés
optimax.pdf (138.57 Ko) Télécharger le fichier
inria-00165639 , version 1 (26-07-2007)
  • HAL Id : inria-00165639 , version 1
Serge Abiteboul, Ioana Manolescu, Spyros Zoupanos. OptimAX: optimizing distributed continuous queries. BDA 2007, Oct 2007, Marseille, France. ⟨inria-00165639⟩
172 Consultations
76 Téléchargements
